This command deletes an area address from the specified routing process.
| area_name | Specifies the area name of the IS-IS process from which to delete the area address. |
| area_address | Specifies the area address name to delete from the IS-IS process. |
None.
If this router process has only one area address configured, this command also causes the routing process to stop sending or processing IS-IS PDUs.
The following command deletes the 0011.03 area address from areax:
configure isis area areax delete area-address 0011.03
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
